When I try to mux a Mac MPEG2 file (m2v extension) and Aiff file I continue to get a failed build. A portion of my file is muxed to MPEG2 (about 5-10 seconds) and looks and sounds great. I went back into FCP and then rexported my files through Compressor and keep on running into the same problems. I have played with the bitrates and haven't seen a solution. Anyone else run into this problem and know how to fix it?
If you're trying to create a DVD-compliant result, then one thing to check is whether that PCM audio stream has the correct sampling rate of 48kHz. If your AIFF is sampled at 44.1kHz, and you have not performed a sample-rate conversion, some problems can arise.
Re-mux m2v aiff to vob freeware
By MaiOns in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2010, 03:54 -
Converting or Muxing audio files (mp3 etc.) into MPEG2 TS without any video
By kary.sharma in forum AudioReplies: 1Last Post: 5th Dec 2008, 10:43 -
By kary.sharma in forum Video ConversionReplies: 1Last Post: 5th Dec 2008, 09:07 -
m2v/aiff to FLV
By btmdan in forum MacReplies: 1Last Post: 22nd Aug 2008, 17:04 -
Problems muxing MPEG2 with layerII Ac.3
By Bonzo2002 in forum ffmpegX general discussionReplies: 0Last Post: 23rd Jun 2007, 12:04
