I need advice on hardware for capturing the following:
8 RGB Sync on Green Inputs
1600x1200 Resolution (minimum)
15 fps (minimum)
The processing will be spanned across two PC's.
Does anyone have any recommendations on capture cards that can handle these inputs and generate the resolution and frame rates I need?
Any and all input is greatly appreciated!
Thanks,
Greg
Originally Posted by Gregus
A classic frame buffer targeted for 3D animation? Won't be cheap. -
This is for a project involving high resolution audio and video capture and storage for archiving and review purposes. Price is not an issue! Or not a big issue shall we say. I've found a card from Foresight Imaging that can do what I want for $3000 USD a piece, and I will need 8 of them.. so that will give you an idea of the budget. Of course, cheaper is always better!
High Res Time Lapse images to AVCHD video (play on Viera TV via SDHC)
By Deefa in forum Video ConversionReplies: 5Last Post: 16th Jun 2010, 04:21 -
Looking For High Res Animation Advice
By David Bethel in forum Newbie / General discussionsReplies: 119Last Post: 8th Mar 2010, 11:09 -
High Res video (elearning)+pentagram eon slide-r Rockchip 2706+8750BG
By mateuszn0 in forum Video ConversionReplies: 5Last Post: 16th Mar 2009, 04:55 -
I need advice on hardware-based in-game video recording
By raykor in forum Capturing and VCRReplies: 4Last Post: 20th Dec 2007, 13:32 -
High Res Presentation video (Frapsed)
By Flawe in forum Video ConversionReplies: 1Last Post: 28th May 2007, 06:01
