VOB2MPG is a great tool and I see that it uses FFMPEG.exe. I don't think that VOB2MPG can be run from the command line, however, perhaps I could use FFMPEG with the same settings that VOB2MPG does.
Could I use FFMPEG to achieve the same results as VOB2MPG? If so, do you know what those settings are? Or even better, if there was a DLL I could just call to achieve the same results.
Thanks.
Results 1 to 10 of 10
Hi there --
I, too, am interested in running vob2mpg from the command line -- I'd like to be able to automate the processing of DVDs from a batch file that has several steps. Is there any way to make vob2mpg do this, or, alternatively, any other program that does the same thing from the command line? -
Hi Scolbath,
I have searched far and wide and cannot find a commandline tool that can perform what vob2mpg does. I will have to resort to one of two approaches, therefore:
1) I might just copy the unprotected VOBs to the HD, join them using "copy /b 1.vob + 2.vob Merged.mpg", however, the MPG is not formatted exactly as I would like it (some flv transcoders have a problem with the MPG when it is simply renamed from a VOB file)
2) I might write a Windows script that will simulate the mouse clicks, etc. That could work if I was running one instance of the VOB2MPG app, however, I foresee issues if I run multiple simultaneous instances
I'll keep you posted via this thread. And if you come across anything, I would love to hear about it.
Thanks. -
I will look into the command line version for you when i get some free time.
Ok i have updated the program... version 2.5:
VOB2MPG now supports command line arguments:
So the assumption is that there will be 2 and only 2 command line arguments. If your paths have spaces you will need to enclose them in double quotes.Code:vob2mpg.exe "path to vob folder" "path to mpg folder"
ChrissyBoy,
If you lived nearby, I'd buy you a beer. Thank you for your time
Just ran it, and it works great.
Just curious: how is it different than copying the VOBs and merging them? There is a difference, I know, since transcoding from the VOB2MPG mpg file always works.
Again, thank you. -
Well it is just that the timestamps can be non sequential in a DVD title and so merged only files can (but not always) cause issues depending on the software you uses afterwards. VOB2MPG merges and resets all the internal timeings in the file.
Posted: Jul 06, 2007 11:56
Posted: Jul 06, 2007 13:38Originally Posted by ChrissyBoyChrissyBoy,Originally Posted by ChrissyBoy
You make AMAZING use of your "free time"!!
Keep up the good work! -
Yes, thanks again much! This makes my current project MUCH easier...!
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
How do i AVS > WMV - the commandline way
By squadjot in forum Video ConversionReplies: 4Last Post: 27th Apr 2009, 07:59 -
commandline ffmpeg & x264 settings for Ipod 5.5
By halsboss in forum Video ConversionReplies: 4Last Post: 8th May 2008, 22:10 -
what ffmpeg commandline should I use ?
By halsboss in forum Video ConversionReplies: 2Last Post: 3rd Apr 2008, 04:49 -
Commandline tool for background
By linkeboda in forum Authoring (DVD)Replies: 5Last Post: 12th Oct 2007, 08:09
