I have recently installed visual studio 2005 pro on vista ultimate 32 bit, under the administrator account. I installed the service pack, as well as the update for vista systems. I then rebooted, and tried out the install - vs starts fine, but trying to create a new project in vb or c# (i have these installed only along with asp) will fail bringing up a dialog box "requested registry access is not allowed" both in the admin account, and my account which has admin privilideges, as well as UAC disabled. I can open up existing projects and compile them as well, but i just can't create new ones. Has anyone else had this issue and been able to fix it?
Some people are only alive because it may be illegal to kill them
Try launching VS with the "Run As Administrator" option (right-click on the VS shortcut).
I had problems with project outputs such as COM objects not being registered properly even though I was logged in as Administrator. Not running with Admin rights prevented registration. The above resolved the problem.John Miller -
i have tried running as administrator. I had set the shortcut properties to always run as administrator.
I tried giving myself complete access rights in the registry - while that enabled me to create new projects in vs, when i reboot - vista doesn't work at all. It will go past the green bar and then go black, white cursor, and nothing.Some people are only alive because it may be illegal to kill them
Corel Video Studio Pro X4 5.1 Sound Problem
By imported_kevsim in forum EditingReplies: 5Last Post: 13th Jun 2011, 19:15 -
ms visual c++ redistributable x64 & x86 2005 or 2008
By runLoganrun in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2008, 11:20 -
computer crashing because of c++ visual 2005 redistributable
By SIRCOOKS in forum ComputerReplies: 3Last Post: 22nd May 2008, 15:35 -
Media Center 2005 or Vista Premium for HD Video Editing/HTPC?
By emartin in forum ComputerReplies: 12Last Post: 22nd Jan 2008, 14:38 -
DVD Lab Pro timecode problem on Vista
By jonghyunchung in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 20:58
