Greetings,
I've just registered as a member here, but been using this site for a while now. I found the info in here to be very useful.
What I've been doing for a while now is converting AVI video to DVD (VOB) format, playable on my DVD player.
Programs that i'm using:
TMEGEnc (for encoding avi to Mkv/Mpeg)
TMPGEnc DVD Author 3 (MKV/Mpeg to DVD format (VOB)
Nero 7 (Burn to disk)
ok.....
I tried using VIRTUAL DUB to set filters to enhance video quality and to get rid of the noise in the video and to sharpen video quality. After encoding in virtual dub with the selected filters....the output file turned out to be 50+GB.....far too large. Am I missing a step here or is there a way to recompress the video to a more managable size to fit a DVD.
The final product on Disk when played on a player seem to be off....I assume its the aspect ratio of the video....looks strected a bit.
Again....any help would be greatly appreciated. I want the video to fit properly on TV and to be able to improve video quality.
thanks!!
You've probably set the output codec to "uncompressed" (or rather - you didn't set it at all) in VirtualDub - hence the huge output.he output file turned out to be 50+GB.....far too large.
When filtering source video for DVD, you should frameserve from VirtualDub to the mpg encoder (TMPGEnc in your case) to avoid intermediate files, and possible generation loss.
Basically you can never improve on digital video quality. What's gone is gone, and can never be recreated.be able to improve video quality.
/Mats
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 18:16 -
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 15:08 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 20:27 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 22:47 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 16:21
