I made a vcd from a vhs tape a while ago and I would like to extract the video and audio to an mpeg or avi file. I am not exactly sure how to do this though I have found some useful explanations on how to extract the video, but there is no sound. Also, I am not sure if this is a VCD or a SVCD, how do I tell the difference?
I'd use the (S)VCD "Disassembly" Tool from VCDEasy. Gets you all the clips, renamed and cleaned of XA mode, ripped and saved to HD.
See pic:
Doesn't matter then if it's VCD or SVCD. You should be able to use either as source for reauthoring to DVD, etc.
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to extract audio from a MKV?
By takearushfan in forum AudioReplies: 3Last Post: 23rd Jul 2010, 23:51 -
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 20:16 -
Extract audio only from VCD
By ambrosechapel in forum AudioReplies: 2Last Post: 19th Aug 2008, 21:24
