  1. Hi All,
    I'm using DVD Lab Pro 2.19.
    For some odd reason when my project goes over 4.5gig, the intro movie will play, but it will never display the main menu. If I remove any movie from the project to get it at or below 4.5gig, it will play fine. Is there something that has to be turned on in order to create a DL disk/project?
    Thanks.
    Matt
    Oct 2006
    Canada
    Check lower right corner of the window and make sure that it display DVD9. There is an arrow next to a text which you can check and it will change from DVD5 to DVD9, or vice versa.
    Other indication of the size is if display bar left of the text is red, your file is too large for DVD size you chose.
  3. Originally Posted by tinker
    Thats was part of my problem, The other one was that fact that I was using Nero to burn a DL disk, which it does a terrible job of. So, someone on this forum recommend using ImgBurn, and it worked like a charm, so all is good now.
    Thanks!
    Matt
