  1. Ok.. since my previous post isnt getting any action ;) ... ill post a new one with new info... I successfully burned one cd using fireburner and the .bin and .cue of the svcd... but for some reason it wont burn the other two.. I dont know why.. It sits at "Synchronizing Cache" and can sit there all day and wont do anything.. just shows the light on the burner going on and off... Can anyone help? Thanks.
  2. I use FireBurner all the time and have never had that problem. Did you change anything from your first success in FireBurner or Hardware. I might try reinstalling program. See if you can get a 2nd success of your first one then. If the first one works again I would say the problem is with the bin/cue file you're trying to burn.
  3. Wolf...I have exactly the same problem. I was able to burn LOTR disc 4, but not disc 2.....stops at "synchronizing"
    Does anyone have any suggestions on other progs to use for BIN/CUE files?
  4. Blindwrite also does bin/cue
    cdrwin
  5. Yea> I had the same problem too, i kept trying to burn my second vcd but there's was always and error.. (restarted my pc but nothing, scandisk or anything else but nothing)
    Until.. I tried Norton Utilities, system check and then I finally burned my second VCD> That Norton utilities has helped me a lot when i get that kind of errors, you should try to get it.. is good....
    Iverson#3
    Jul 2001
    Maryland
    maybe you could extract the files from the bin/cue file.
  7. Originally Posted by Greg12
    I could extract the file with ISO buster.
    Is there any difference in burning the MPG file instead of burning the BIN/CUE?
