Hi guys,
First I must say that I'm a newbie.![]()
I wanted to upgrade firmware on my Philips DVP5960 dvd player because the audio was terribly choppy when playing back some DivX.
So, I got the disk, it seemed like the upgrade started but then it just froze, the screen went black (said "no signal") and now the dvd display says "PHILIPS" and the player does not respond to anything, tray is closed and won't open, I can't even turn it off unless I unplug.![]()
Please, help me! I am stuck and don't know what to do!!!![]()
Thank you!!!!
Read this:
https://forum.videohelp.com/topic301465.html
You have to push one of the buttons on the front.
"...the "HD Upscale" button on the front of the unit had to be cycled." -
Thanks for your response, unfortunately this does not solve my problem. The player remains unresponsive, message on the DVD screen remains the same. No luck.Originally Posted by Jeremiah58
Is return to a store an option?
Don't tell them about your "upgrade", though.
Where did you get that disk?
If you bought it with a credit card, it should be under guarantee for a year or so.
Philips DVDR5520 -looking for firmware upgrade/hack for mpeg4
By kbozis in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Apr 2010, 17:03 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 19:45 -
Philips DVP5960 custom firmware?
By bluepassat in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jul 2008, 13:49 -
Philips DVP5960/12 Firmware 12.06.36.24 download it here
By F-Swed in forum DVD & Blu-ray PlayersReplies: 92Last Post: 11th Apr 2008, 22:48 -
Philips DVP5960 - firmware "upgrade" to fix jerky video is a &quo
By tzikeh in forum DVD & Blu-ray PlayersReplies: 13Last Post: 18th Nov 2007, 15:47
