    Jun 2007
    I've just installed ffmpegX to convert some QuickTime mov files to a file compatible with Windows (MOV-mpeg-4) for a client but when I drop the Quicktime.mov file into the Source Format box I get 'Unrecognized' in the window?
    I am obviously doing something fundamentally wrong here. I have checked to Decode with QT box but still no joy. Is there any other settings that I must deploy to do this conversion sucessfully?
    Simone
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Please provide some details on your source file. What does QuickTime Player say about the content/codecs? Do a Cmd-I and/or Cmd-J to access details.
    Jun 2007
    All it says is the following:
    FORMAT 16-bit Integer (Big Endian), Stereo, 44.100 kHz
    H.264 Decoder, 720 x 576, Millions
    FPS: 25
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Hmm, that's odd. ffmpegX should have no trouble recognizing the file, as it does when I try to create a H.264/PCM file.
    Maybe there is more to it, like proprietary headers or DRM, hard to tell without access to the file to try out a few things.
    Jun 2007
    I tried various prepared QuickTime files in different compressions and codecs but none are 'Recognized' - Maybe ffmegX is not designed to do the job?
    Many thnaks
