I upgraded but it doesnt seem to be working right..the dvd burner doesnt want to read some dvd's. So I thought I would see if I can go back to the original firmware..thanks for any help
There is no way of knowning what the version of the "original" firmware. Someone may be able to help you locate previous versions...but how will you know which one is the original?
Your best bet is to trouble shoot the actual problem you are now having. Most likely it isn't related to your previous or current firmware.Google is your Friend
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Is it possible to flash firmware onto a non-original DVD burner???
By suomalainen in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2009, 17:17 -
Sony DVD RW 820A lead-0ut problem.
By WORLD2000 in forum DVD & Blu-ray WritersReplies: 2Last Post: 25th Jul 2007, 20:47 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
