    Nov 2005
    I have heard many explanations and a multitude of varied answers so i thought i'd ask at a place where i know the users know what they're talking about.Here we go...
    here's what i was wondering..is there a way to make a menu for a VOB titleset w/o re-encoding the movie itself?I hear that older versions of TMPG dvd author can do this..Since the Files are already VOB'd,is there an application or a way to accomplish this? Basically,just making a menu and attaching it to the VOB's
    Jan 2007
    I gues if you have the skill PGC edit might do it?
    I couldn't fine a way to do it , the other day..
    i had a vob set , but the menu ifo bup vts was screwed and the DVD would not play, all the vobs would play in my player programs
    I ended up re-authoring all over again
    I ask for a program to scan the vobs and create a simple run titleset
    I got no response to that part of my post
  3. AFAIK, TDA can still do it and probably any other DVD Authoring programs. I know Nerovision will do it; at first it might seem it's re-encoding, but it's not. It demuxes the VOBs and if they are DVD compliant, it remuxes them when authoring. Then there's DVDAuthorGUI.
    Nov 2005
    thanx guys...i'm gonna try dvd author gui and see what comes of it
