Hi,
I’ve read a bunch of different ways on how to burn mdf files onto disc media but how do you extract vob files from dvds made in the form of an mdf file? Is there a free program out there that will let me do this? thanks
Mount as a virtual dvd drive with daemon tools and you can copy the files.
thanks! that worked, well kind of. I did so and copied the files with dvd decrypter (cause it wouldnt' let me copy them manually) but I still couldn't open the 3rd and 4th vobs??!!! I can't figure out why. I had no problem opening up the first two. All of my movies were like this. It says the 3rd and 4th are copied but no player can open the vob up and I have no problems with playing video files because I have tons of different players for every extension possible. Any idea why?Originally Posted by Baldrick
VOB files aren't meant to be played.
Try extracting the mpg out of the VOBs with VOB2MPG.
/Mats -
maybe so, but why would i not be able to play the last 2 vobs? i usually just convert the .vob files into avi's, but none of the conversion software would even recognize it. i've never had this problem before with disc images, it only started when i first ran into the mdf format. I don't think it's going to work VOB2MPG, but I'll give it a shot. thank you.Originally Posted by mats.hogberg
I wouldn't be surprised if it didn't work with VOB2MPG - in which case it seems like the VOBs that refuse to play are somehow damaged.Originally Posted by uglijimus
Have you burned the mdf to disk, to create the Video DVD? Did it play fine all the way thru?
/Mats -
unfortunately i can't burn it to disc or else that's what I would do. My dvd rom won't recognize blank dvd media, but that's a different topic. However, when i did mount it to a virtual drive (DAemon tools) it played all the way through. I've read tons of posts on mdfs but most people are not trying to extract the vobs. But from what I gathered, the mdf is the main file and sometimes there is a md0 or a md1 inside the folder. These are usually much smaller than the mdf. In my case however, the mdf was around 2 gig and the other md0 was 1 gig which i thought was a little strange. Don't know if this anything to do with my problem. I'm thinking about getting an external DVD drive but it's going to be a big hassle to burn to a dvd, then extract the vobs from it. As far as the vobs being damaged, i wonder why only the last 2 vobs on both movies were damaged?? Too much of a coincidence I think...Originally Posted by mats.hogberg
mdf is just like an iso, but with the advantage that it can be split in chunks. Shouldn't affect the content at all.
/Mats
Getting two fatal errors when extracting mpgs from vobs
By Antony in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Apr 2012, 01:24 -
VOB2MPG-PRO: Problem extracting VOBs from Verbatim DVD+R Dual Layer (8.5GB)
By rickyp513 in forum DVD RippingReplies: 1Last Post: 25th Aug 2010, 17:47 -
extracting vobs by episodes
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 5th Apr 2010, 01:54 -
Extracting VOBs To M2V gives me alot of problems.
By Discov3r3d in forum DVD RippingReplies: 5Last Post: 18th Aug 2009, 16:41 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 14:01
