i have a question...if i have a hd movie on my computer and i wanted to play this on my hd dvd player can i burn the movie using my dvd writer? or would i need a new writer that supports writing to hd?
AnonymousGuest
You can burn hd-dvd video on dvd but it might not work an all hddvd players, try for example ulead dvd moviefactory.
But you need a new writer if you want to burn HD-DVDrs. -
AnonymousGuest...but would the output be of same quality? if i was to do that i would have to compress the video wouldnt i? wouldnt doing that make the output just like a normal dvd? or would it be hd?Originally Posted by Baldrick
thanks for your help! -
Yes, the quality will be hd but you wont be able to fit as much as on a hd-dvd media.
AnonymousGuest
ok thanks alot! just one more thing...you say i wont be able to fit as much, but do you think i would be able to fit a complete hd movie on a dvd, without all the other stuff. and would it need compressing? i dont have a clue how big a hd movie is!
About 20min to play on your Toshiba HD-A1 or near 40 min if you can get dual layer to work. I'm wondering if anyone has gotten dual layer to work.Originally Posted by selim97
I have burned HD-DVD's on double layer DVD's using Ulead DVD Movie Factory to author the HD-DVD. I usually get about an hour's worth of content on one DVD+R DL, but when the bitrate is low enough I have managed to get an entire 90 min. movie on one disc. AVSForum.com has a guide on how to do this.
Converting and Burning DVDs
By OtosReborn in forum Portable VideoReplies: 13Last Post: 6th Apr 2010, 21:59 -
Problem with Burning DVDs
By The Monkees in forum MacReplies: 2Last Post: 25th Oct 2009, 02:00 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 13:53 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 19:08 -
trouble burning DVDs
By nick177th in forum DVD RippingReplies: 9Last Post: 5th Oct 2007, 17:10
