Poorly worded, I did mean the rate alone does not determine quality, otherwise it wouldn't matter what method or encoder was used. As the saying goes: "Faster, cheaper, better -- choose any two".Originally Posted by NiteLite
Results 31 to 33 of 33
@All
on't let this disintegrate into a squabble over what's to be considered quality or not.
@OP:There's only one way to fit more (timewise) onto a disk, and that's lowering the bitrate. Lower bitrate means lower quality. Only you can be the judge here, what's acceptable and what's not. Not me, not AlanHK, not LordSmurf or anyone else. Just you.
/Mats -
Here is another way to do it.Originally Posted by ells6363
You can re-encode with TMPGEnc (or the encoder of your choice) to DVD specification using DVD NTSC (or PAL) "low resolution" option = 352x240 @29.97fps (352x288 @ 25fps for PAL).
Using this spec. you can fit upto 4.5 hours per DVD5 disk.
But this method will take sometime to re-encode if you have a slow computer. And you still have to author the re-encoded files.
If you want more episodes per disk, then there is VCD spec. if you don't mind lower quality.
Converting Multiple Chapter DVDs into one single MP4 file
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 14:02 -
Encoding in 720p to single or double-layer DVDs?
By broaddd in forum Blu-ray RippingReplies: 2Last Post: 12th Feb 2009, 00:41 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
Splitting 8GB DVD into 2 single layer dvds
By omega_weapon in forum ComputerReplies: 4Last Post: 16th Aug 2008, 12:17 -
How do I import multiple dvds then edit them into a single compilation?
By bumblebee21 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 15:33
