Hi everyone,
I am currently running Win2k, CCE 2.5, DivX Codec 4.12. I am trying to encode a DivX to VCD/SVCD using CCE 2.5, but I get the following error:
"Couldn't find appropriate video codec for 'div3'"
I can play DivX movies just fine with Windows Media and other players.
Thanks,
-B-
Ok..I finally Uninstalled DivX Codec 4.12 and install DivX 3.11 Alpha Codec and it works now for that specific DivX file.
Now I tried to encode another DivX file, but CCE 2.5 crashes when I try using it with VirtualDub frameserve.
Any suggestions?
Thanks,
-B- -
If I recall, you need to run CCE under Windows95 compatibility mode. Under Win2K, use ATCOMPAT.EXE (or something like that) which is not installed with Win2K but it's on the Win2K CD somewhere. Under WinXP, 'compatibility mode' is available by going to the program files properties and clicking on the compatibility tab.
good luck. -
hi
if you dont use any virtualdub filters/plugins you can try this:
http://www.geocities.com/team286/divx2svcd.zipWell, I am the slime from your video.
Oozin' along on your livin'room floor. -
Originally Posted by mkanar
I finally got CCE 2.5 working with VirtualDub 1.4.7. What I had to do was
- uninstall my Divx 4.12 Codec.
- install the Divx 3.11 Alpha Codec.
- reinstall Divx 4.12 Codec, but when it asked me if I wanted to use this coded for Divx 3, I said no.
I don't know if that had anything to do with it, but CCE 2.5 seems to work with Virtual 1.4.7 frameserve under win2k now. I've been using TMPGE prior to trying CCE 2.5 and CCE 2.5 does seem alot faster. I don't know whether the video quality is better though. The only thing that bugs me is the damn LOGO! I've been reading the post on here and every seems to be annoyed with that too. Any suggestions besides speding $2000?
-B-
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
