Results 1 to 12 of 12
  1. Member TerryNG's Avatar
    Feb 2004
    Hi,
    I was wondering if anyone could help me with a menu design. I have a rather large image that I'm wanting to use as a menu background. I would like to have it look like the camera is panning around the image instead of showing the whole image as the background. Is there an easy way to do this? I usually use Vegas for my video editing, so if it could be done in that it would be ideal.
    Terry
  2. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    DVDLabPro 2 has special panoramic menu option.
  3. Member TerryNG's Avatar
    Feb 2004
    Thanks for the post, I'll check it out.
    Apr 2004
    Miskatonic U
    It depends what sort of effect you want.
    If you just want the camera to pan left to right, then back again, constantly in the background, use Track Motion and keyframes in Vegas to create a video clip, and use this as your menu background.
    If you want the menu to move around the image when choices are made then it becomes more complex, which is where DLP 2's panorama option might help.
    Read my blog here.
  5. Member TerryNG's Avatar
    Feb 2004
    I was hoping to have a bit of vertical motion in the menu, but if horizontal would be easiest, then I can deal with that. The source image is pretty big, 3140x4710, so I should be able to do some cutting and rearranging to make it wide enough to make it look good.
    Edit for clarity: I'm just wanting constant panning in the background, totally independent from any selections that are being made. If you've seen the menus for the dualdisc version of the Nine Inch Nails album The Downward Sprial, that's what I'm wanting to go for without the color changing effect.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    With Track Motion you can zoom in and out, move up, down, left, and right or diagonally.
    Again, though, what effect are you after for the menu ?
    Read my blog here.
  7. Member TerryNG's Avatar
    Feb 2004
    Track motion sounds like the way to go, thanks for the help.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Pans (of still images) can easily be created with MS PhotoStory.
    /Mats
  9. Member TerryNG's Avatar
    Feb 2004
    hmmmm, never heard of photostory. I'll have to give it a look.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you use Photostory (and it is actually pretty good for a Microsoft freebie) install the templates from Papajohn's site. They improve the quality a lot. Photostory's biggest failing is that it only outputs WMVs. It is also limited to a single move per image, although by repeating images you can fake around it. Track Motion, on the other hand, can do anything, including 3D moves if required.
    Read my blog here.
  11. Member TerryNG's Avatar
    Feb 2004
    Yeah, I've been playing with Track Motion in Vegas and it's giving me exactly what I wanted.
    Thanks again to everyone who offered help.
