Am I the only one who does not know this? Looks like it's a common knowledge ever since. Perhaps I did not read the manual very carefully.
After using two Sony HDV tapes, then two JVC tapes, then two Panasonic tapes, my barely used HC-3 suddenly won't play or record. The error message - "head is dirty." After using a Sony head cleaner, it kind of works albeit with occassional dropouts.
For six years, I have used a Digital8 with a mix of tapes (whatever on sale) and this did not happen to me.
I also read that, years ago, Sony already reformulated its lubricant so that is does not react with the other brand. NOT.
After all that Sony has done to @#$% us ... you still are buying their products?
Interesting, I've heard this before and others have declared it a "urban myth". Could be it's not the tapes that are the cause of your problems and it's just a coincidence. Whatever the case to be on the safe side I've only purchased one brand of tape and intend on sticking with it.
http://www.tapestockonline.com/minidvtapefaqs.html
I'm not sure about the accuracy of the statements but there are many others about this topic.
BTW, I used the $12 Sony HDV tape and the Panasonic brand which are both made in Japan. I read that you should use a head cleaner first before using a different brand of tape if you are not sure of the lubricant used. -
A similar thing happened to me with the same three tape types. I had been using only JVC with no problems, but found some Sony and Panasonic tapes on sale. Big mistake.Originally Posted by edong
After several passes with a cleaning tape, I was able to restore the performance of my camcorder. Ever since then I have used only JVC tapes, and things are fine once again.Life is better when you focus on the signals instead of the noise. -
It is known that Sony uses a wet lubricant while some others use a dry lubricant. Mixing tapes can cause problems as you've already seen.
Once you get your tape head fixed choose one tape and stick with it.
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 20:53 -
Restoring VHS tapes with a mix of NTSC and PAL-M encodings?
By leon43 in forum RestorationReplies: 5Last Post: 24th Nov 2008, 06:31 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
Going HD with Sony - but with lots of Panasonic miniDV tapes to cap
By japniz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 13th Mar 2008, 23:14
