  1. Does anyone know why a DVD that plays back smoothly in PowerDVD plays back choppy in Media Player Classic (which, unlike PowerDVD, has free DTS decoding)? When i first downloaded MPC, it played wonderfully and the DTS decoded to two speakers or headphone with an impression of greater dimension than the AC3. I don't know why it doesn't play back smoothly anymore. The video is choppy and the audio is distorted on both AC3 and DTS.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Most likely, it is now using a different codec than it was when you first installed it.
    Somewhere among all these posts are procedures on changing which codecs are used. You could also use a program such as codecsniper to search/remove bad missing codecs.
    Google is your Friend
