What are some good ways to convert a screensaver to a video? Which methods would be lossless or provide the best quality?
				Results 1 to 9 of 9
	Some screen capture app, that records to AVI?
 /Mats
	If you can get a screen cap to grab it, well and good, although many won't cap screensavers. The other problem is that screensavers often use strangely high CPU levels, which can make screen capping harder.
 Easiest is to plug your PC into a DVDR and record it from there.Read my blog here.
	Thanks for the responses. I tried with a screen capture program, Camtasia, but the results are rather choppy, as you predicted. I may go the route you suggested, going from S-Video Out on my computer's video card to the Analog In recording on my Canon Elura DV cam, or even hauling my Toshiba RD-XS35 DVR into the computer room.
 But before all that, is there a more direct way, for example a little app that converts screensavers to video directly? A quick Google turned up a few programs that go the other way, turning your video into a screensaver. I'm looking for the opposite.
	No, mostly because most screensavers are executable programs that just happens to br writing graphics to your screen. It's not a matter of converting data from one format to another, because that data doesn't exist. To do what you are suggesting you would have to basically set up a virtual PC that captured the screen output to a video stream instead of to the monitor. Lot of work just to grab a screensaver output. Read my blog here.
	Some screen savers are in fact an AVI file and an app that plays it - IIRC the old MS "Bliss" screen saver was one such. If that's the case here, just grab the AVI and you're basically home free.
 /Mats
	Progress, sort of: I located the content of the screensaver tucked away in a folder in Windows/System 32. It's an .swf file I've managed to play with something I googled and downloaded called Swiff Player, but when I try to convert it with Super, it errors out, and WinAVI also gives me an error ("Can not find FLASHWINDOW component, must exit...", then "Failed in initializing the file(s)!").
 Any ideas?
	It sounds like what you have is a 'regular' Shockwave Flash file. SUPER (as well as many of the other video converters) only handles Flash Video within an .FLV. I've heard that sometimes, Flash Video can be embedded within a .SWF, but I've personally never seen it.
 To convert the .SWF, you'll need one of the various Flash/SWF to AVI programs out there (though I've never really had much luck with any of the free ones; the commercial/shareware ones might be better). Or try using the video capture programs again (might be a better idea to try CamStudio instead of Camtasia, or maybe Fraps). You may have better luck, since you'd be capturing directly from the .SWF and not trying to capture from a running screensaver. If cameras add ten pounds, why would people want to eat them? If cameras add ten pounds, why would people want to eat them?
	Success! The freeware SWF2AVI failed, but something called ADShareit SWF to Video Converter Pro worked.
 Thanks for the help, everybody.
  Convert video to .scr (Screensaver)By fitch.j in forum Video ConversionReplies: 9Last Post: 27th Jun 2012, 12:56
  Looking For A Free Video ScreensaverBy DJboutit in forum Newbie / General discussionsReplies: 2Last Post: 6th Apr 2012, 14:29
  Looking to convert scr files (screensaver slideshows) to avi or mpg formatBy wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 18:28
  ScreenSaver to AVI -MPEGBy arturjose in forum Video ConversionReplies: 3Last Post: 25th Oct 2007, 10:03
  Convert screensaver files to some form of movie?By michaelmcgennan in forum MacReplies: 3Last Post: 27th May 2007, 09:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
