Guys can you shed some light on this.
When i open my system restore all i get is a blank page, so any problems i get with my pc im unable to restore it back to when it was working properly.
Im not sure if it has anything to do with the problems i had a while ago where i was getting error messages on some links.
Thanks.
From what I've read, the problem may be connected to Internet Explorer and problems with it. Try this link: http://bertk.mvps.org/html/tips.html#BlankWindow
Basically:
Go to Start -> Run and type or paste each of the following commands, one at a time while pressing enter after each one.
regsvr32 jscript
regsvr32 vbscript
regsvr32 /i mshtml -
redwudze,
i done as you said but on the last one i done i got this message:
mshtml was loaded but the dll register server entry point was not found.
mshtml does not appear to be a .DLL or OCX file.
The other to was ok. -
Well next step open a command prompt.
start, run, cmd
in the dos box type sfc /scannow and windows will check for corrupt, deleted and changed files. You will need your XP disk handy.
It is also quite possible that you have a Malware infestation. One of their tricks is to disable System Restore, Disable Antivirus and Anti Spyware programs, change your search page and/or home page and so on.
System Restore
By tcory in forum ComputerReplies: 10Last Post: 21st Dec 2010, 03:13 -
Space used by System Restore?
By bevills1 in forum ComputerReplies: 5Last Post: 3rd Jan 2010, 11:12 -
system restore problem
By Willy5157 in forum ComputerReplies: 2Last Post: 11th Oct 2009, 18:46 -
What does it mean? Create a system restore.
By alintatoc in forum ComputerReplies: 4Last Post: 24th Mar 2009, 05:41 -
XP system restore points
By CSULB71 in forum ComputerReplies: 5Last Post: 16th Apr 2008, 11:12
