hows it going everyone....Can someone who has used VEGAS inform me if this is possible. But I want to decrease the volume of one whole song during a particular time. Like for example, decrease it by -2 db in the middle of the song for like 10 seconds and fade it back to the original volume? Not decrease it to mute, but lower the volume? I dont know if it will or not, but all I can do is fade the song in or out completely from/to mute. Thanks guys.
yea sure -- very easy
see "insert/remove envelope" in manual
or right click on track and use "insert/remove envelope""Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yeah i just figured it out before coming back on here and looking at your response. I didnt see anyone help me so I just played around and got it to work. But yeah it has to do with the audio envelope and automation and blah blah...thanks though for the response.
You don't need to use automation. Just click on the audio track and press "V" to show the volume envelope. Then double click and drag to create and move points on the envelope. Also investigate Ctrl- & Alt-dragging of points (only move vert & horiz.), double-clicking of a point (returns it to zero) and also pressing "D" to switch to the envelope editing tool (will only move envelope points without moving the clip, by mistake, beneath the envelope curve).
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Sony Vegas 9 Audio Problem
By fdegrano in forum EditingReplies: 4Last Post: 24th Jan 2010, 20:13 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum Capturing and VCRReplies: 3Last Post: 29th May 2008, 09:22 -
Sony Vegas 6 Audio
By Sunshine3012 in forum DVD RippingReplies: 2Last Post: 25th Oct 2007, 23:32 -
sony vegas audio
By romik91 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 16:37
