I'm a newbie to a lot of this stuff, so please bear with me.
I have this Sony DVD cam which records directly to mini DVD discs. However, all my DVD players are slot loading players, except for one DVD drive that I had to literally buy just to read the discs.
Now I would LIKE to play these on a dvd player (and the mrs' folks want a copy of the DVDs too) so I'm trying to find a way to put say 2 mini DVDs into one regular 4.7GB DVD.
The only way I could do this, keeping all the menus and chapter points seemed like to use TMPGENC DVD Authoring tool with DIVX. Unfortunately, TMPGENC seems to want to re-encode the everything all over again and keeps crashing. I think this is because its trying to create an NTSC dvd out, and the original are PAL.
Is there any OTHER way to do this..? Cant I just copy all the fines in the Video_TS folder into one DVD..?
Or any other good proggie..?
Please help..
	You can set your project to PAL so it doesn't re-encode . . .
 About the only way to keep menus and everything intact and join two discs together is DVD Remake. It will create a new top level menu that will allow you to pick disc one or two, and then go their menu from there.
 DVD Shrink in Re-author mode will allow you to bring all the titles together, with chapter points, but you will loose all the menus. These could be re-created in another program though.
 I would start by setting up your tmpgenc DVD author project correctly and trying again.Read my blog here.
  Longevity of Standard DVDs and BluRay DVDsBy bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32
  Problem with burning DVDs...wont fit but shouldBy JediMindTrick in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2010, 09:37
  DVD Rom can burn DVDs but won't recognize burnt DVDs.By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03
  How many 4.7 Gig DVDs may fit into 500 gig HDD?By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 10:40
  I want software that copies DVDs and transfers torrents to playable DVDs!By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
