Is there a way to convert VCD 1.1 to VCD 2.0?
Can I just drag the .dat file back into nero and burn to get a VCD 2.0 version or do I have to re-encode or something completely different?
no reencoding is required but you can convert the dat to mpg(www.vcdhelp.com/convertdat.htm it will not affect the quality) and then add it in nero...or try vcdeasy.
Converted back to mpeg and reburnt with nero and it's still not VCD 2.0?
Why not and how do I get it to be?
Need to convert to to VCD 2.0 as it plays out of sync in one of my players unless its VCd 2.0 -
www.vcdhelp.com/vcdeasyhowto.htm then to...if not that work it may be some other problems.
Tried that baldrick and same. Actually the disc I'm trying says its DVCD not VCD 1.1 as I first thought. But still the same. Just reencoded a short 10 second burst and this seems a lot closer to being in sync.
Surely there's and easier way than re encoding all these 5 movies that I have acquired.
After reencoding with Tempenc disc now shows as VCD2.0, when just using VCDGear or VCDEasy it still shows as DVCD and is out of sync???
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 15:00 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Poorly sized video on converting VCD to DVD
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2007, 01:39
