Hi,
how can I easy make a good dvd from my HDV recorded files captured with cancorder Sony HDR HC7?
Can I use ConvertxtoDvd?
Peter.
Hi,
when using one off the above tools for converting hdv to standaard dvd, is the output dvd going to be better then converting dv to standaard dvd?
Will I lose video quality?
Peter -
You will lose video quality when converting HD to DVD. Maybe time for a HD-DVD writer and HD-DVD Player ?
You have to loose quality simply because to convert to DVD you have to throw away 75% of your video data (resolution). You can influence just how much quality you loose by your choice of software. ConvertXtoDVD is great for taking average quality Divx files and creating DVDs. However it is not the highest quality encoder, and will produce much lower quality results from your source than other options.
You are better off looking at a good editor that has the mainconcept encoder built-in, and using that for your encoding.Read my blog here.
Hi,
when I use mainconcept encoder for converting from hdv to dvd
is the output standaard dvd going to be better then converting dv to standaard dvd?
I am thinking of buying the Sony HDR HC7, but I have only a standaard jvc dvd player.
Peter.
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 21:44 -
HDV to DVD
By uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 19th Mar 2011, 04:53 -
hdv/dv to dvd: to deinterlace or not?
By arod0405 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2009, 10:07 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2008, 14:05 -
HDV to DVD
By josel in forum Newbie / General discussionsReplies: 2Last Post: 10th Nov 2007, 14:55
