Hi ya,
Is anyone using 2.5 with XP64?
I coul dget 2.1 working fine... there was always a small error on startup but you just continued and it never gave any problems [Exception from HRESULT: 0x80040241.]
Now with 2.5 when you start it you get this error message -
Version: SVCD2DVD 2.5
Build: 2.5.2718.30637
Type: System.Runtime.InteropServices.COMException
Source: System.Windows.Forms
Message: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
InnerException:
StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
You then get an Application Error - Process ID=0x458 (1112) Thread ID=0xb70 (2928)
Couple of things to check:
if you installed the program in the default location can you open a command prompt and type:
regsvr32 "C:\Program Files\BadgerIT\SVCD2DVD v2.5\code-lock.ocx"
and if you don't get an error - try re-running SVCD2DVD.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
i had the same
InnerException:
with the "old" version (2714 or so) it work fine -
Ok. I think i have sorted this. Can you redownload the program and reinstall - and let me know if the issue is gone?
You're a star!
Whatever you did it worked a treat.
Installed and registered.
If it works as well as the other versions i'll have nothing to complain about
Thanks dude! I <3 this proggy. -
Cool x64 users!!! - thanks for the confirmation.
DeVeDe 3.16.9 build 2 Mencoder "bug" error under XP64
By mail2tom in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 20:35
