I have burned a dvd of home movies using imgburn.
Now, I need to go back and edit a clip of the dvd. I have extracted all of the files from the dvd to my hard drive using dvd decrypter.
After that, I tried using dvdx to convert the video_ts to mpeg format. The video came out perfectly, but the audio was choppy at best.
I then tried using AutoGK to convert the video_ts. This program gives me perfect video, but no sound at all.
The output file size is of no concern right now.
Any help or suggestions would be greatly appreciated.
Rip all files with dvd decrypter.
Open the video_ts/vts_01_xx.ifo in AutoGK and convert to AVI. -
Perhaps you are one of those people with the mistaken impression that you MUST convert to AVI to edit. That is not true. Guns1inger's suggestion is excellent. Use VideoReDo or MPEGVCR to edit your video after you rip it. There is no need to convert to AVI just to edit the clip. Both VideoReDo and MPEGVCR allow you to try before you buy, so make the edits as you need with one of them and then convert the video (if you must) or re-author a new DVD.
( I assumed you wanted an avi....if you just want to edit dvds use tmpgenc dvd author!!!! Import from the dvd directly.
Converted video (mp4): audio out of sync
By darknezx in forum Video ConversionReplies: 4Last Post: 22nd Mar 2011, 03:25 -
Converted audio shorter than video
By rjc7394 in forum AudioReplies: 0Last Post: 15th Jun 2010, 01:14 -
Help!!! Converted video drops audio about half way through.
By jimwelch1957 in forum Video ConversionReplies: 2Last Post: 23rd May 2010, 06:52 -
No audio with converted video files
By TomLJ in forum Video ConversionReplies: 10Last Post: 7th Oct 2009, 15:47 -
Converted video has no audio
By franks65 in forum ffmpegX general discussionReplies: 5Last Post: 2nd Sep 2008, 09:43
