Hi all have just updated my pc with AMD AM2 5600X2 DUAL CORE CPU & ECS MOTHERBOARD K8M890M-M with a new sata HD my dvd burner worked ok before the upgraded . any think i try to copy now cd or dvd just ejects the disc telling me to put cd or dvd in the drive the burning speed are different now as well cd speed 40 or 32 dvd's are 1x upto 18x burner is a Pioneer 212 sata worked great before upgrade . now running hd and burner by sata . Be fore upgrade only had pioneer burn using sata conection.
thescotsman
some SATA burners have problems with the mobo SATA chipset. although if using a mobo w/intel chipset there aren't problems. i suspect your mobo has the VIA chipset. update the VIA drivers on your mobo.
It could also be that the burner SATA drive number has changed (like moving an IDE drive from Master to Slave or vice versa). Try uninstalling/reinstalling your burning software (or perform a bus scan if possible), this will allow the software to rescan the system bus and identify all of the attached burners.
And as Budz pointed out, it's always a good idea to update drivers.
And yes, that MB is a VIA chipset board.Google is your Friend
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 08:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02 -
New Pioneer 212...I dont have SATA!
By vm711 in forum Newbie / General discussionsReplies: 2Last Post: 18th May 2007, 11:41
