Results 1 to 12 of 12
    Jun 2007
    South Africa
    is there a GUI for avisynth?
    Apr 2004
    Miskatonic U
    AvsP has the added ability to allow you to create sliders to control parameters, and to see the results in a preview window.
    Read my blog here.
    Jun 2007
    South Africa
    WOW,thanks guys but one more question,i dowloaded dll's for filters for avisynth but will they work with the proggies you guys mentioned?
    Sep 2006
    VirtualDub could be considered a GUI for AviSynth.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Avisynth does all the work. The programs mentioned are really just editors of one degree or another. If it is an avisynth filter, it will work.
    Read my blog here.
    Jun 2007
    South Africa
    Ok but i downloaded some .dll's from warpsharp these dll's are necessary to make filters or scripts for avisynth to use so will they work with the progs you mentioned?
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If they work with AviSynth, they'll work. All AviSynth GUIs are basically just fronts, to create AviSynth .avs scripts
    /Mats
    Jun 2007
    South Africa
    so i can go an download more .dll's to use right?
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If you need them, yes. But I'd start using what I have before diving into the filter dll ocean...
    /Mats
    Jun 2007
    South Africa
    thanks bro really appreciate it
