I have pictures from a friend taken in 1949 on a DVD. I want to isolate some of the pictures. I can't ask her to go through her pictures again.
How do I convert the slideshow to power point, or capture individual pictures
Please respond to sabobariti@earthlink.net. Your message will go to my spam blocker and i will be notified.
thanks
Riti
	A friend had her friend scan some pictures from 1950 and it was place in a slideshow in VTS VOB format. There are some old pictures I would like to print but I can't capture them.
 How do I convert to a jpg, pdf or power point
	your hi-jacking a thread
 but the few slide show discs i have seen did not contain video files.
 just copy the files to your PC to a folder of choose, then use a photo slide show program to open the files and extract the pictures
 what program did she use to create the slide show, kodak, adobe photo shop, photo elements, ulead,
 ask her, then get the same program and open the files
 there is a chance your PC already has the means to display and print or extract these pictures
	1) Welcome to VideoHelp. Please read the rules before posting, thank you.
 2) Please don't thread-jack. I've split this off as a separate thread.
 3) This is not a forum for private counseling. It's a community, where you get answers in the forum.
 4) Read the stickies - https://forum.videohelp.com/topic239865.html
 Now, if your slide show is in Video DVD format, the best resolution you'll get is 720x480/576 (NTSC/PAL) - Not exactly excellent material for high res printouts...
 /Mats
	Most DVD slideshows are in fact video - either video tracks or mpeg encoded stills. While many players will play back jpeg files, jpeg is not part of the DVD standard, and DVD slideshows are not made up of jpeg files.
 Mats has pointed you in the best direction, and unfortunately you will never get stills from your DVD that match the quality of the opriginal photographs.Read my blog here.
  Puting a slide show and a video separately onto the same DVDBy coastie in forum Authoring (DVD)Replies: 3Last Post: 10th Sep 2011, 05:44
  dvd w/ video & picture slide showBy hymnatr in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2008, 11:51
  DVD Slide Show DuplicationBy KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27
  slide show video with proshow producer to avchd on blu ray diskBy LEONESVIZZERO in forum Authoring (Blu-ray)Replies: 1Last Post: 21st Apr 2008, 04:39
  Adding slide show to a movied DVDBy leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 09:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
