hi..i need some help.
i convert dat to mpeg using vcdgear.
the fisrt disc was great but i hve problem with disc 2.
there is no sound at all.
is there any other way..
Results 1 to 10 of 10
Have you played the disc to verify it actually has working audio?
Google is your Friend -
if you are not going to do anything but play the vcd, just change the file extension from .dat to .mpg and it will work in software players.
actually i download the movie.
it is in dat format and it have 2 files.
i want to convert to mpg so it can play on my vcd player.
i don't have problem to convert the first file.
i have try to play the the second file on my computer..the audio is working.but when i convert to mpg ive got problem with the sound.
what's wrong?? -
yes,for the fisrt file only..i got no problem with it.
but the second file still got no sound after i convert..
i can only play it on my computer with the change of the file extension. -
you could try demuxing - remuxing with a tool like the one included in old tmpgenc versions. it is in file/mpeg tools - the merge and cut option/mpeg-1 videoCD setting. only put the one file in there and let it rewrite the file. there was also a standalone version of mpeg tools.
ok..i never try this b4.
something new..
hope this will be ok.
thanx alot for your help guys.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 13:57 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 16:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 27th Sep 2008, 00:18
