    May 2007
    every time I try to use a dvd ripper and convert to divix the video comes out ok, but the audio goes silent every 10-15 seconds or so. I reviewd the various setting and can't find the problem.
    Apr 2004
    Miskatonic U
    You need to be a little more specific.
    What software are you actually using ?
    Do you see this problem when playing back divx files you didn't encode ?
    Does it happen no matter what software you use ?
    Do the files play OK on another computer ?
    Read my blog here.
  3. Member SanderMan's Avatar
    Feb 2001
    Netherlands
    Try Autogk or Fairuse Wizard. See if that makes a difference.
