Hi, I have DVD9 VOB files on my hdd and am completely unable to move these files to a DVD9 disc since I do not have a dual layer burner.
Is there an app that will convert these files off of my HDD and make a DVD5 ISO or DVD5 VOB files to be burned to a DVD5 disc?
If you have all the files required (VOBs, IFOs, BUPs) then you can load them into DVD Shrink and from there either transcode them down to fit, or re-author to movie only.
Read my blog here.
Internal or external DL burners are "inexpensive"....
Why convert..??
Or why not cut your video's in half...???
Use 2 regular's....
You just have a BIG file ...
Being DL ??????????
Does the file say it's DL ?? How do you know they are???
Forum GURU's correct me if I'm wrong...... -
For the sake of one title? DL writers may be inexpensive these days but reliable DL media certainly isn't.Originally Posted by JimboS
...and have the nuisance of changing discs half way through?Originally Posted by JimboS
If it's a single title and bigger than 4.7GB then it must be DL.Originally Posted by JimboS -
Thanks Guns1inger... I had DVD Shrink this whole time and never noticed the open files option. I feel dumb now
And ntscuser... thanks for clarifying Jimbos problems haha... I didnt wanna have too.
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 17:52 -
The best possible quality of DVD9 to DVD5
By Charmer in forum DVD RippingReplies: 37Last Post: 28th Apr 2010, 20:00 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 11:33 -
DVD9 To DVD5
By taylor6698 in forum DVD RippingReplies: 3Last Post: 22nd Oct 2007, 21:36 -
dvd9 to dvd5 using dvdshrink
By rancid in forum DVD RippingReplies: 7Last Post: 14th May 2007, 22:52
