ok so i had an old drive that i had questinons on, and found it was dying.. So i bought a new one. i need one that would read both dvd-rs and dvd+rs. So i found a..
Memorex DVD+-RAM 525G V1
Now the drive works great except that fact that it jumps to PIO mode after 3 or 4 burns. i have found that i can just uninstall the driver to the secondary IDE channel and that fixes it for another 3 or 4 burns then i have to do it again. Anyone know the reason for this? anything i need to upgrade to stop this from happening? I returned the first Drive i bought (same one as stated above), incase it was the drive. The new one does the same thing.
I was just wondering if there was a reason this was happening?
CAN I HAVE YOUR COOKIES? -
http://support.microsoft.com/kb/817472#appliesto
you'll have to edit the windows registry by going through regedit. take a look at that link. -
I would seriously consider replacing the cable and get an 80 wire one too. Is this drive alone on the cable? I had problems with LG DVD-ROM not playing nice with Plextor drives; tried 2 different models, no luck. Got a Benq, problem fixed.
ive had it alone and with another drive. Either way it still jumps to PIO. WHat about the cords it gives you with the drive. I didnt hook that up, just used the one that was still in the comp. Should i try using the new cord before buying one? you say 80 wire? whats the one that comes with your comp?
You'll need to buy a 80 wire ide cable to use with your new dvd burner. Most new dvd burners require that in order for it to work correctly.
Here's a online shop you could buy from:
Cost is $1.49 from SVC.com
http://www.svc.com/rc18hd2-sil.html -
i will do that, and i will let youu know the outcome. ThanX
External hard drive sleep mode
By hamilton accie in forum ComputerReplies: 4Last Post: 9th Feb 2012, 11:36 -
PIO Mode After Encoding & Other Stuff
By Tom Saurus in forum ComputerReplies: 66Last Post: 20th Jul 2011, 16:38 -
question about adding prohibited user options (prevent pgc jumping)
By mazinz in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2010, 13:03 -
PIO mode detector???
By AlecWest in forum DVD & Blu-ray WritersReplies: 12Last Post: 12th May 2010, 14:49 -
how to check which udma mode is supported by drive?
By cL0N31 in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Oct 2007, 23:19
