I have my movie converted to .avi using Xmpeg 4.2a and am ready to burn to cd. I have converted the movie to two different avi's, one is 300mb and the other is 575mb. I have the newest version of nero 5.5.6.9 which supports avi's. The problem is that no matter which file I use, nero ignores the file size and uses the time (93min), which is too long for a cd. What am I doing wrong?![]()
I have the same version of Nero and have burned about 20+ VCDs, but to answer you question Nero does not use the file size when converting to VCD, rather the duration of the actual clip. Hence if you have a clip(s) that is more than 800MB in size but less than 80 min, then it will still fit onto one VCD, unless you recorder supports overburn. Hope this helps out some
. Also it would save time to convert the movie to an VCD compliant mpeg (mpeg1 format). That would save time too since Nero takes forever to do the conversion for you.
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 11:54 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 18:36 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
