How likely is it that a DVD drive could be damaging disks? I have had a large number of bad disks since getting a new Gateway computer with a HL-DT-ST DVD-RW GSA H11N drive. It has been very slow to spin up and recognize disks but I can't veryify that it is bad in order to have it replaced. Could the slow spin-up be a warning sign? The disks that are going bad are Sony DVD+RW disks (1 1/2 years old but unused until recently) and some new Memorex DVD+RW disks on a 25 spindle. Earlier Memores disks performed well, though some of them have been going bad recently, too.
Welcome to VideoHelp!
To make your stay as pleasant as possible, please take your time to read our rules.
Among those, you'll find:
This once, I've split your post off as a new thread.Originally Posted by Rules
/Mats -
There is no way to know for sure without doing a little troubleshooting. Try the discs in a different pc/burner and see if they work or not. If they do, they your burner could be the trouble, it they don't...then it's the discs. Spin up time isn't a good indication...some drives are just slow to spin up.
Google is your Friend -
First thing I'd do is update firmware if you haven't already. Firmware update can improve media compatibility.
Use a different brand of DVD+RW media. MEMOREX is crappy media.Originally Posted by Jo A
From the supplied information, it is by no means certain that the drive is defective.
In order to get a factory replacement, it is not necessary that YOU verify the drive is bad. It is only necessary to verify to the FACTORY that the drive is bad.
If a user calls the factory and reports that the drive will not read commercially produced disks, both DVD and CD, and most especially reports that the case has never been opened and that the FIRMWARE HAS NEVER BEEN UPDATED BY THE USER, the factory will almost certainly replace the drive. Update that firmware and your warranty goes bye-bye.
The answer for virus BS is to attempt to boot from a Windows installation CD. If boot order is properly set, and it does not boot from a known bootable CD, the drive is bad. There is a PERIOD at the end of that sentence. -
I agree with budz!!!
*** Now that you have read me, do some other things. *** -
In the past the gateway versions of LG drives have had an OEM model number and will not accept updates from the LG site. (I have checked and H11s are oem versions).
Gateway's Bigfix program provided automatic updates to the firmware.
It is possible to cross-flash your OEM unit to an H10N or H12N. Discussion of this and procedures are discussed on the LG forum at
www.cdfreaks.com
I suspect updating the firmware to be a waste of time. Besides your elderly SONY media is probably older than the drive and likely to already have a write strategy in the firmware.
LG drives are ususally media tolerant including with so-called "crap" media.
Are there signs of physical damage on your disks?
Can you write DVD +R or -R media?
Is the slow spin up the only reason you think that the disks are going bad?
Are they disks you have written on the drive?
Do you verify when you write?
Do they read elsewhere?
Samsung SH-S243D DVD writer - CD media burn quality
By onland in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Feb 2012, 22:52 -
Finding a BDXL writer AND best place to buy 50 GB media
By AARRGGHHH in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jan 2012, 11:06 -
Cutting without damaging source.
By Stikke in forum EditingReplies: 8Last Post: 17th Aug 2011, 13:52 -
Is Bluetooth Headsets For PS3 Damaging?
By Nitro89 in forum Off topicReplies: 5Last Post: 16th Dec 2008, 05:06 -
Help w/ replacing an audio track on a DVD (w/o damaging menus, subtitles)
By svenge in forum DVD RippingReplies: 5Last Post: 29th Jun 2008, 01:37
