I've just built a new PC and now can't capture segmented video in VDub.
I'm using a Mavel G400 as my capture card.
VDub will capture OK in compatability (AVICap) mode but is then limited to producing a 4Gb file.
If I try a multisegmnet capture using VDubs regular capture mode using I get the message:
"Warning: No frames captured.
Make sure your capture card is functioning correctly and that a valid video source is connected. You might also try turning off overlay, reducing the image size, or reducing the image to 24 or 16-bit."
As far as I can tell, all my settings as as they were before!
Thanks for any halp you can offer
Nezza
Best you select the CODEC of your own capture-device. (for compression, you must select "No recompression"
If your card doesn't have its own CODEC (then you proberly have a low cost capture device), use HUFYUV if the output of yout cap-device is YUH (or something like this) or MJPeG if the output is RGB(A).
Don't select to high quality if you don't have a fast system. It will lead in too many dropped frames.
Trouble with capture - ATI HD750/VDub
By TB Player in forum Capturing and VCRReplies: 10Last Post: 23rd Jan 2012, 17:37 -
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 16:24 -
VDub setup for VHS Capture
By HDClown in forum Capturing and VCRReplies: 16Last Post: 27th Apr 2010, 03:48 -
split fields in vdub capture
By greenbag in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 22:50 -
Not Working?? Capture with BFG 7800GTX and vDub
By DW in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2008, 15:12
