I have a video I edited in Premiere Pro. It's standard 4:3 SD format.
I'd like to put it up on the internet in Flash FLV format larger than 320 x 240. Any suggestions for what's the largest size I should use?
i never done any , only watched some, but I think it depends on where its going, no matter what you send youtube, it will be resized to 320*240
google uses larger, and if you are putting it on your own site, you can use what ever size you want
bigger sizes make bigger files and take longer to reach the viewers PC -
I will be hosting it myself...i want it to be larger than 320 x 240 but I still want it to load relatively quickly for DSL/Cable users.
Then it will be a matter or trial and error. Create different resolutions and check the file sizes. The bottom line is file size, not resolution.
Google is your Friend
trying to download flash video but there's no flv
By newbie789 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Jun 2011, 20:48 -
Alpha channel video makes for a larger-than-target bitrate flv
By flvvideo in forum Video ConversionReplies: 1Last Post: 3rd Dec 2009, 12:10 -
DVD to FLV (Flash 8 Video)
By foochuck in forum Video ConversionReplies: 3Last Post: 27th Jun 2007, 07:20 -
I can only capture at 320*240!!
By MisterBubbles in forum Capturing and VCRReplies: 1Last Post: 13th Jun 2007, 22:36
