Since I am already on the run i might as well post another one,
One of the burnings from my stand-alone player does not seem ok,This is a small part of what I get when trying to encode it to XviD:
a52: error at resampling
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
a52: CRC check failed!
Too many video packets in the buffer: (4096 in 8268025 bytes).
How to resolve this issue using FFmpegX? Mplayer seems to be able to play the source just fine, but the encoding does not work. What to do?
Results 1 to 1 of 1
