Well, a week ago i bought a brand new Sharp DV-SV90S who is not moltiregioned. Now it is on Region 2 so could any1 help me find this hack? cuz this hack what was in this website wasnt helpful.Waiting for help.
Results 1 to 14 of 14
Not all players can be made region free. Why did you buy a region 2 player if you wanted a region free?
/Mats -
didnt know i don't know wery much about this regions when i bought it i wanted to play a DVD from my pc and it didnt readed it.my friend electronic told that i must make it multiregioned and told me to search the net for hacks and i didnt found so i thinked that any1 will tell me how to hack it.
What's "a DVD from my PC"? A home made Video DVD on DVD-R (or other recoirdable DVD media)? If so, it's with 99.999% certainty region free, and the reason why it wont play is something else.
/Mats -
well,i don't know how to explain it but when i load my player and press "menu 1 3 5 7" it shows that now i'm in region:L but i want to make it Multiregioned .That;s what i need.and the DVD from my pc was a downloaded Torrent so i writed it to a DVD disk and inserted it to my DVD player and it was reading and reading it and a board appeared with a folder ROOT\ ...
Assuming we're not talking about a pirated commercial DVD here:Originally Posted by PhyRo
1000 to one the downloaded DVD is region free. Your problem is not region coding. The fact you see a "ROOT\" tells me your player is seeing the disk as a data disk, not a Video DVD disk. What exactly did you DL - an ISO or what? How did you write these to disk? What do you see on the disk when you open it in Windows Explorer?
/Mats -
I downloaded a lot of .iso files and extracted the first 1. then i burned it with Nero 7 >make video DVD and then putted in my DVD player. and it throws out a window with ROOT\ . Also , when i tried to find a multiregion hack in this website i found this https://www.videohelp.com/dvdhacks/sharp-dv-sv90s/7076 . It's a region code hack.I downloaded that file and did everything like it was in the instructions. i wrote a file "C2M3AWRP.rom" . But! when i inserted the disk (CD) it showed the same window with ROOT\ ... but in the instructions its writen "4. After burning process is completed, place the update CD into the DVD tray and press play button.
5.
Wait to see the update process steps as shown below. When the sw. Update is completed unit will switch itself to standby mode. "
so i dont know what's the problem.
Any suggestions? -
That's your problem. Just burn the ISO to DVD with ImgBurn. Forget about the region free hack for now. It's not your problem in this case.Originally Posted by PhyRo
/Mats -
Damn it.when i insert the written dvd with the movie it reads it and then writes "Wrong Region" ...what should i do? I Told You that its not Multiregioned..
I bet that means "Wrong TV System". Nothing you can do about that, besides doing a TV system conversion of your DVD. Many players seem to display the generic "Wrong Region" when in fact they are actually complaining about a PAL/NTSC issue. (Your player is NTSC and the DVD is PAL or the other way around.)
May I again add, that only (or close enough to only) commercial pressed DVDs have region code protection.
/Mats -
NTSC and PAL are color systems and they dont have do to anything wiht the DVD reading.I use PAL (Europe) . But if i will put NTSC it will show the image in black & white ,but that doesn't got anything wiht the DVD (as i told) My Friend says i still have to make it multiregion , or it will still not work at all...
Hey so Maybe anyone found how to make this player multiregioned? please anyone help ;\\
How do I set a LG DVT499H into multiregion?
By ELCROWLEY in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Aug 2009, 13:24 -
Multiregion code for LG DK7821P
By ieh4f in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2008, 16:11 -
JVC XV-n650B need multiregion hack
By mairel in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2007, 13:53 -
LG HT-302SD MultiRegion Hack
By Xqbz23 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Jun 2007, 19:38 -
multiregion hack
By chrissi34 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jun 2007, 17:59
