i have a video on Hi8 casstte film in my video camera and i cant load it to my pc without lots of jerking and audio corruption.ive tried pinnacle 700...help!
	what codec are you using to compress the capture? Or just plain uncompressed AVI? Sounds also like you are getting tons of dropped frames... can be caused by a bad tape, or a hard drive not capable of the transfer rate required... You are in breach of the forum rules and are being banned. Do not post false information.
 /Moderator John Q. Publik
	Use fire wire instead of USB, in my old Hi8 the USB port did exactly the same thing.
  Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 7th Oct 2017, 12:34
  How to increase when TC OR CAM DVD to Tc or Cam ripBy antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 14:42
  Help me with a project. Convert 8mm film to DVD.By flyin-lowe in forum Authoring (DVD)Replies: 5Last Post: 8th Oct 2010, 09:37
  Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVDBy scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 13:49
  Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVDBy scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 01:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
