I have seen plenty of advice on ntsc to pal conversions when starting from avi, dvd or dv or something, but none so far which explain how to take a dvd ready mpeg2 from ntsc to pal.
If I just author the mpeg2 as is, I don't think my dvd recorder (philips dvdr610) is able to play the dvd. So is there any guide I have missed that you link so I can burn a pal dvd instead?
I'm hoping to avoid the "one stop shop" methods as all the advice I've seen so far reckons the loss of quality isn't worth the convenience
TIA
I would be surprised if it can't, as the vast majority of PAL kit will play NTSC source.
That said, the first question you need to answer is what is the framerate ?
If it is 29.970 then there is no way you can nicely convert it to PAL without getting a jerky or blended results. You have to discard frames, and the results are never pretty.
If the framerate is 23.976 then the process is not difficult. Resize to PAL resolution using avisynth, encode at 23.976, apply pulldown using DGPulldown to change the playback from 23.976 to 25 fps, and author as PAL.
Finally, if the framerate is 29.976, but it has come from 23.976 source then you may be able to inverse telecine the video back to 23.976 progressive, and then convert to PAL as described above.
Or you could just give ConvertXtoDVD a try and see if you are happy with the results.Read my blog here.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 28th Sep 2009, 00:05 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 16:07 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 19:26
