Hey Guys,
Im new to all this so take it easy. Anyways, I am trying to convert some AVI files which are about 40 mins long to a DVD. I tried to put 3 of the AVI files on the DVD and the first 2 play fine on my DVD player, but the the last AVI file is always choppy. I thought maybe 3 files were to much so I tried 2 and again the last file is always choppy. Am I doing something wrong or is it the conversion program?
It sounds more like it is the quality of the discs you are using. Especially because it is always the last video that suffers. DVD blanks are created by dropping the dye onto the bottom disc platter and spinning it to push the dye to the outer edges. The top platter is then dropped on and the disc sealed (in a nutshell). If the manufacturing is not up to scratch, the dye at the outer edges is not as consistent as the dye closer to the middle, so the quality of the burn suffers. DVDs burn from the inside to the outside on the first layer, so it is the end of the burn, and therefore the end of the video, that suffers.
The fix is to always buy good quality media, not just the cheapest available. read www.nomorecoasters.com for details on what's what in media land.Read my blog here.
Convertxtodvd video encoding help
By nutman in forum Video ConversionReplies: 1Last Post: 8th Dec 2010, 06:08 -
AVS Video Converter vs ConvertxtoDVD
By kuerenz in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 10:44 -
Video BRIGHTER when AVI to DVD (ConvertXToDVD)
By Ace-Of-Spades in forum Video ConversionReplies: 8Last Post: 6th Sep 2009, 12:33 -
ConvertXtoDVD v2.2.3.258 Problems..Jerky Video...
By sandman423 in forum Authoring (DVD)Replies: 6Last Post: 4th Dec 2007, 13:06 -
ConvertXtoDVD to encode and burn video files to DVD
By crowheart in forum Video ConversionReplies: 15Last Post: 16th May 2007, 22:50
