Help! I was finally able to edit my MPEGs in Adobe Premiere using the AVISynth plugin and AVS scripts, and it has been working fine, but now, after a TON of editing, every time I try to render any part of the project, I get a big fat program crash! I can't even render a small portion of the video! What has happened? Do I need to change settings in the "Premiere AVS Plugin GUI"? Is it running out of memory?
I have an older version of the same Premiere project (before recovery) and it seems to render fine. The one that is having trouble is a previously-recovered file after a different error that I saved and simply continued editing. The messages can be viewed as Bitmap images in the attached ZIP archive.
This is not good... my class project is due tomorrow and I have gone through all this work!
adobepremiereerror.zip
Have you opened the avs file in virtualdub to test it first ?
That would be my first step.Read my blog here.
There's just too many options to mull over...
If it's a rush (like you say it is), start over by reloading all your Mpegs, and saving out as Microsoft DV AVI file...
Since Premiere was meant as a DV editor, simply open up a fresh project, and reload the previously saved out .AVI.....
Good luck!!
Adobe premiere cs5 crashes on start-up
By sonic12345 in forum EditingReplies: 14Last Post: 13th Nov 2010, 19:16 -
Rendering with Adobe Premiere Elements decreases visual quality
By AuditSup in forum Newbie / General discussionsReplies: 17Last Post: 27th Mar 2010, 13:37 -
Help rendering a finished video with Adobe Premiere Pro 2
By metathran in forum EditingReplies: 21Last Post: 30th Jan 2010, 12:12 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 22nd Apr 2009, 00:16 -
adobe premiere rendering issues...
By dazndan04 in forum EditingReplies: 9Last Post: 15th Aug 2007, 02:21
