Clicking noises usually means the HDD is "dead" on the physical level. My problem was more of a formatting and/or partitioning problem.Originally Posted by fLYtRap
That clicking noise usually means you are screwed![]()
- John "FulciLives" Coleman
Results 61 to 64 of 64
Did you read this document. I've seen comments there about dead drives just like mine have been putting into freezers overnight to shrink metal and than they where able to recover the data from them on the time limit bases, until the metal parts of the drive went back to its original size. It is only about 20-30 minutes window to get things done. Some people there repeated the process several times to get whole data back. I am reserving this TRICK as a last resortOriginally Posted by FulciLives
moved to another forum, nobody likes me here... -
Just to revive this thread for a quick moment ... Im curious.
This thread was geared towards recovering files on a drive that is unreadable.
Would the same advice in this thread apply to a drive that was accidentally formatted? Could the programs and tips above be used to recover any data on the drive?
Thank you kindly
LG -
As long as you don't write anything to the drive then there are unformat and format recovery programs out there.
Formatting does not remove any data. It just rewrites the file allocation table.
You will have to do a search as I do not recall any specific ones right now.
Recover corrupted recorded file form Sony PMW-EX1
By elmuz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Mar 2012, 05:38 -
MP4 (AVC) Recover after SD filled up and all headers or footer corrupted.
By Bunkah in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2011, 12:09 -
recover *.mts files from external HDD ..tried restoring hdd software
By ravistudios in forum RestorationReplies: 0Last Post: 18th Mar 2010, 13:24 -
Diskeeper UNdelete Vs Get Data Recover my Files
By mn072065 in forum ComputerReplies: 5Last Post: 26th Aug 2008, 12:26 -
question about how to recover corrupted photos
By jimdagys in forum Newbie / General discussionsReplies: 6Last Post: 3rd Mar 2008, 08:57
