  1. Is it possible to get 5.1 audio recorded when i convert it to dvd using VSO software?
    Apr 2004
    Miskatonic U
    No. If it has DVD compliant 5.1 audio then ConvertXtoDVD will use it. If it has non-DVD compliant audio then ConvertXtoDVD will convert it to 2 channel AC3 at 192 kbps.
    If you want to convert 2 channel to 5.1 you might want to look at this post : https://forum.videohelp.com/topic326127.html and convert the audio before using ConvertXtoDVD to create the DVD.
    Read my blog here.
