    Jun 2007
    I published a vista movie maker file into an .avi file. The quality is excellant. I then used WinAvi Converter (the free trial version) to convert to a vcd file. The picture quality is blurry. Is there a setting I should be looking at changing?
    I am a novice at this
  2. VCD has a resolution of only 352x240. It will be blurry compared to a 720x480 DV AVI (or similar) file. WinAVI probably also did a blend deinterlace which would have made high action scenes look blurry or like double exposures if your source was interlaced.
    Jun 2007
    Thanks for the info. What is the format I need to convert my .avi file into, in oder to lpay in a stand alone dvd player connected to my TV?
  4. MPEG 2 with a frame size of 720x480 and DVD compatible settings. If your video is interlaced leave it interlaced. Do not deinterlace.
    Jun 2007
    Ok I am trying it now....converting to MPEG2.
    do I have to do anything with these settings:
    23.976 fps-NTSC Film Rate or
    24 fps Standard Film Rate or
    29.97 fps-NTSC Rate
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    For tv viewing use the last setting. If you're leaving it on the computer any will work. But settop dvd uses the 29.97 rate.
