Hello,
I have tried to use the AVISynth AVS function directshowsource() to play a .ram RealMedia audio file, but gives me an error "Cannot play back the file. The format is not supported."
When opening it in RealPlayer or RealPlayer Alternative, it first couldn't play without RealPlayer downloading a codec, and then it did play (in both programs). However, the AVS script still can't read it.
Addendum 1: I tried using Jodix's RM to MP3 converter (http://www.rm-mp3.org/) to open the file, but says "The following file can NOT be read correctly." and strangely, "You need to update your DirectX to version 8.1 or higher." dxdiag tells me the version is 9.0c.
When files require RealPlayer to download new software or codecs, are those downloads supposed to be applied to the directshowsource() function as well?
Thanks for any help
Results 1 to 1 of 1
Unable to play FULL SBS to Anaglyph using Avisynth 2.5
By BaltarWithSix in forum Video ConversionReplies: 17Last Post: 24th Jan 2012, 00:11 -
MOV files won't play audio - RAM problem?
By MJW01 in forum AudioReplies: 1Last Post: 18th Nov 2011, 05:26 -
How to play and convert the RealMedia VBR?
By coody in forum Software PlayingReplies: 6Last Post: 29th Sep 2008, 19:33 -
codec for realmedia
By pcb in forum Newbie / General discussionsReplies: 13Last Post: 3rd Jun 2008, 07:47 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 18:15
