Hello,
I've got a .ppp file. Does someone know how I can convert it to a file, what I can watch in mediaplayer or something like that.
thanks already
I have never heard of that form. Where did you get it? How was it created?
http://filext.com/file-extension/PPP -
it was created after putting 2 videofiles together.
I can't find something more then that link on the internet.
Only thing that I found more was that a .ppp files is used by camcorders.
ps. hope you can understand it, my english is not great
Try dropping the file in Gspot 2.70. It may be able to identify the format. And you could try playing it with VLC media player as it plays most files.
And are you sure that .ppp is the extension? Is the file the proper size? Have you turned off 'Hide extensions for known file types' in 'Folder Options>View'? Otherwise you may not be seeing the true extension name.
And welcome to our forums.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
