alway use svcd2dvd to join any 2 cd files
but they always come up as wide screen
i've gone into the options and choose to create as pal, but its still widescreen
any help please
PAL or NTSC have nothing to do with widescreen which is what you appear to be saying. If the video is widescreen and you force it to fill a 4:3 screen everything will look really tall and skinny. The other option is to loose things that may be happening at both sides by trimming them off. I myself as you may have inferred prefer to see it widescreen even if it doesn't fill the whole screen.
Indeed - if the source is ultimatly 16:9 then so will be the DVD. If you want it full (and so loose some of the picture), you can zoom via the TV or DVD player.
3d movie has spilt screen I want it full screen please help.
By stadelbauer in forum Newbie / General discussionsReplies: 9Last Post: 18th Dec 2013, 18:46 -
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23
